Markblox
Any special technique for adjusting the chain or do I just undo the bolts and wrestle the wheel back, making sure it stays inline?
After you've got the adjustment right and tightened the axle bolt, tighten up the adjuster bolts or they'll come loose and rattle or fall out![]()
Tony
Tony
Thanks, I done all that yesterday, At first I didn't notice the bolts to adjust it with. Anyway done the nut up to 60 IBs/FT. I noticed I should have replaced the chain as the rear sprocket is quite badly worn. In the past month I have been doing about 500 miles per week to work and only noticed the chain was stretched last week. The tyres are pretty worn now too. Any advice on where to get all this sorted? I live near Brighton and the nearest main dealer is in Guildford but I don't know of anywhere else I could take it. Will the front sprocket be worn out in your experience as well. I suppose I should LOOK but I'm not sure it's visible. Anyway, thanks for your help. Mark
Tony
Front sprocket hidden behind an easily removed cover - it will show signs of wear! I found the front sprocket wore twice as fast as the rear. Replacing the front early will help the chain and rear sprocket last longer.Will the front sprocket be worn out in your experience as well. I suppose I should LOOK but I'm not sure it's visible.
Hi replaced the chain and sprockets on my Funduro about a year ago, after much searching around for the best price to my amazement buying the genuine parts from BMW was the cheapest. This is normally a fairly straight forward job however the genuine chain is endless (no joining link) therefor I had to remove the swinging arm to fit the new parts.Think I am correct in saying that if you buy an aftermarket chain kit it will come with a rivet type link. Removing the swinging arm isn't a big job and gives you a good opportunity to grease up the swinging arm and lower linkage bearings![]()
Thanks for that, I may do it myself, if I can be bothered. Out of interest, how much did the parts cost?
IIRC £68 but if you cant be bothered thenI would suspect you will have to add a few hundred to that
I've just changed my sprockets and chain. Being lazy I got a split chain but just before I did the job I read about the swingarm bearings being prone to failing and thought I might as well check them. Good job I did because one looked like it had spent it's life in the sea. I had to get a new bearing sleeve too because it was so corroded and the dealers don't seem to stock them so that took a week. I remember now why I've got an 1100 for my commuting
