Yesterday I changed my alternator on my 2009GS. Although I knew it had a cracked casing, it was still running.
Just in case anyone plans a similar job, I thought I could outline some points as some of the original descriptions are not so easy to find now.
Tank and beak off; expose belt and remove (during this phase the heads came off 2 small bolts from the upper cover). Put jack under engine, disconnect electrics from front ESA shock from connector and move out of way along with the fluid lines - this looks more complicated than it was, as it all unbolts easily. Remove and replace alternator from the front. Put back together. Search for where the bolt left over should go. The jack is useful to adjust the height to get the lower shock bolt in and support the weight with the shock out. Copious amounts of penetrating oil used. Beer.
Tonight I took some photos of the inside of the alternator for interest - definitely worth avoiding the pressure washer on this area.
