Just a quick update on progress:
1) New diode board confirmed it wasn't the diode board. On the bright side, I now have a spare for next time.
2) I discovered the "diode mode" on my multimeter (thanks
@Strongbow92 !) - which also confirmed it wasn't the diode board (d'oh!).
3) Tested the Stator and continuity and resistance was as it should be.
4) Removed rotor and confirmed resistance between the rings is 0.8 Ohms - so bugger me, it was the rotor all along.
So far I have learnt:
1) Multimeters do more than check voltage and continuity.
2) Simply wishing that the problem is the easiest component to replace (first regulator then diode board) is a poor substitute for actual proper testing
3) This forum is freakin' awesome (and has been for over 20 years!).
Replacement rotor on order, will report back on progress.
Have a great weekend all!
