Phil Clarke
My rear pads were getting fairly worn after 20k (read it and weep abs types) but nothing too urgent (not picked up in a service a fortnight a go). Anyway coming into a roundabout the other day the pedal went right down to the stop with no brake at all. Stopped to check and discovered the pads worn completely away and the fluid level gone completely. When i got home and removed the pads they had no backing material left at all and it looked suspiciously like the pads had been ripped off the backing plates, which would explain the sudden loss of pressure in the brake. Anyway new pads and a protracted brake bleeding sesh have sorted it but it may be worth checking your pads if they are well worn to avoid a similar mishap.
Phil
Phil
