Panzer Patrol
My non-technical understanding is: the effect is at tickover and very light throttle openings when engine is not under load. Light throttle when not under load appears to be where people suffer the dreaded surging.
The surging may be occuring because the system is switching between open and closed loop at this point, or it is running borderline weak.
The techlusion adds juice only, so it feeds the weak mixture area and stops the surging. It also adds juice where the user defines in the range which, when it is set right, gets rid of any emission based flat spots allowing the engine to rev through this point cleanly. This gives the motor the chance to rev freely without any hesitation, hence the increased seat of the pants performance. The cost is increased mpg. This affects riders in different ways. If they tend to ride their bike in or around this rpm area they may notice a significant increase in mpg. Others see an increase but not enough to be bothered.
Adjusting the throttle position sensor is not difficult. A simple DIGITAL multi-meter and a bit of fine wire is all that is required. The effects, especially if the TPS is set on the low end of the tolerances can be quite noticeable, showing a much better throttle response and pick-up.
However, I am usually wrong so feel free to ignore, heckle, tack the p1ss, whatever
