carphone
Hi all, has anyone replaced the clutch on an 04 twinspark yet or got an 04 onwards manual?
The clutch has 7 plates instead of the previous 8 and the manual I have does not list the correct dimensions for checking the lined plate and clutch pack thickness. I need the updated dimensions.
Also the pressure plate seems to have about 2 mm of wear / recess on the friction face. Is a new pressure plate recessed on the friction side or is it flush?
There is nothing wrong with it but I want to check it all out while I am replacing the water pump, which coincidentally was not leaking but on inspection wear was evident and it would not have been long before it started.
Mike.
Mike.
