I have bled the clutch. It wasn't too hard but I kept squirting DOT 4 everywhere.
Anyway the bike runs fine but initially the clutch would only work correctly on Lever setting number 3. I went back to it later and changed the setting to 2. That works better and the bite is less fierce. On setting 3 the bite would kick in after releasing the lever just a couple of millimeters.
Is there any way of adjusting the lever at the handlebar end to get the requisite 10mm of free play and therefore set the clutch right and be able to tell how much life its got left. As you would be able to with a cable clutch lever.
Only got the front brakes left to do but thats going to wait until i have a Mityvac or whatever else someone might suggest.
isn't very good because it covers so many models and I want a factory manual now.
I don't know if the Clymer is model specific or any more detailed.
