1100 clutch problems
Your mileage is about right for a seal failure on clutch pushrod shaft of gearbox.
When the seal behind the clutch pushrod lever fails, gear oil makes it's way down the pushrod & is centrifuged outwards onto the clutch plate.
Clutch then slips on hard acceleration, but not always. ( Temperature dependant)
If doing job yourself, do not buy bits until bike is dismantled.
When you remove clutch, if driven plate is oily, replace it only.
Pull out clutch pushrod. If it is oily, you have to strip the gearbox to every last component to replace the rear pushrod seal. if gearbox is heated to 100 degrees C, it is easily dismantled. If done cold, sealing faces will be damaged in the dismantling, & the shims will be scattered in the pulling. so do it hot.
Gearbox takes 6 hours to replace all seals in it.
I have not done a GS, only An RT so I cannot tell you how long to take out gearbox, but it is a lot quicker & easier than an RT. (24 hours to remove & replace gearbox)
Be cautioned, therefore, on current quotation, because you are likely faced with a gearbox strip as well, & dealer has not costed for this.
Regards Michael.
If you have any queries, email me at:
mmcnamee@btconnect.com
