Bit of the thread hijack, hope no one minds, but as i've a query re another clutch issue i thought i'd add it here.
Been out on my 850 again today and my clutch is getting to the point where it bites right at the end of the levers travel. I'd normally guess this suggests i'm due a clutch change. Its a 2000 with 49k, ridden pretty hard by me since about 22k. But, theres no sign of any slippage, even when ragged pretty hard. Coming home earlier by myself I gave it some pretty harsh abuse to see if i could get it to slip, but nothing.
Is it worth looking at anything else before pulling the box off and fitting a new clutch? Could the cable have stretched with age,? There's no slack in it. Or did i read somewhere that the 1100's, that the 850's are based on, suffers from an issue with the actuating lever at the box end of thngs?
The main adjustment is at the rear of the gearbox on the clutch arm.... You must have play on that arm.
