Clutch reservoir
I set the oil level with handlebars turned to get the pot as level as possible, then (carefully) drop in the rubber bellows and put on the lid. I only had level problems when the slave cylinder banjo sprang a leak. The oil is clear and clean so left no obvious stain on the swing arm. A pair of Dowty washers sorted it.
Seems it's just the way the light shines through the reservoir, so a non-existant problem.
Nothing to see. Move along.....
:augie
:blast
:hide
