Richard P
The clutch on my 12,500 mile 1150GS has started to slip but only when I cane the engine.
The clutch works fine when the engine is at normal temperature and unstressed but if I give it the jelly - 7500 in 3rd / 4th (it has a vile flat spot between 5 and 6,000) for a mile or so then slow down for a junction, the clutch slips in the lower gears but works normally again after a mile or so of sedate riding.
Is this a sign of an impending terminal problem?
Asside from "don't cane it" is there a cure that doesn't involve replacing the whole thing?
thanks in advance
Richard
thanks in advance
Richard
