As the mornings are getting a bit colder I have experienced a small problem with my 2008 GSA.
After I have been riding a minute or two, when i pull the clutch in at the end of my road sometimes the motor just dies, once it does its a bit tricky to start.
It only seems to happen if the temperature is below 5C. I have plugged in my GS911 and it shows no faults. I have checked the TB balance and it looks almost perfect. I didn't check valves clearances but I assume if the TB balance is Ok then valves cant be too far off.
Any ideas what might cause this? I feel like it needs to idle a little higher when cold but there is no adjustment for idle speed. Maybe I just need to start the engine before moving out of the garage so it warms up a little before riding off?
Thanks.
Thanks.
