compact Nautilus air horn
MEDICMAN
Near Malvern, Worcestershire.
Hi all
Sorry if this has already been asked before but can anybody tell me if this will fit, out of sight, under the side panels of a new 1200GS?
Timmies rules please. :)
How should I know. I just know that the last time i asked what I thought was a sensible question other's thought, "Hey! here's an opportunity to take the Mitchell." :D
The little scallywags.:rolleyes:
It does fit
Hi all
I have a 2008 GS, but it is not fitted with esa, so I have mounted the Nautilus where the from bit fits. Have photos if you want to see them,
Regards
Nigel
gsa
if you need to separate the compressor from the horn the hole in the horn will self tap to 1/8 bsp (thread lock a 1/8 bsp nipple in) and vacuum pipe from halfords, warmed up (hot water) and stretched over nose pliers and held in place on the comp. and nipple with petrol pipe clips works. there are plenty of threads on fitting these to gsa`s but not to sure on gs`s
best of luck they are well woth the effort.:thumb2
