Got given a compression tester for my birthday recently and put it to the test the other day . Ive been trying to get my 100 to run smoothly for a while and having done the full carb refurb, including new cables it was still a bit "off". I thested the compressions and found the right hand side was a bit down so checked the valve clearances again and found the inlet a bit tight. all now sorted with the same compression on both sides. My question now is , what should the readings be, any ideas.
