confused and exhausted
bobcat
Sorry to be a pain, but is it possible to remove my silencer and replace it with a y piece(where from) and carry out no modifications on my 2003 1150gs twin spark head, and cause no damage to the bike.
Thank you to any one who can help
Bob:hide
Yep.
I removed the CAT and fitted the Y-piece. No other mods and ran fine.
10,000 km later I fitted a Remus end can, also ran fine with no other mods. Later the filter was changed to K&N, fit a carbon fibre (wider) induct and then did the Cat Code Plug thing ... since removed. Seems (TOUCH WOOD! :aidan ) fine!
I bought my Y-piece and Can from Motoworks at
http://www.motorworks.co.uk/
Nick
P.S. the reason for moving on from simple y-piece replacement was the classic 'just can't leave it alone' ailment!
I fitted a Y piece to my 2003 twin spark and found the bike ran weak at high revs, tried Steptoes mod but still ran weak. I went back to the original setup in the end. the bike runs fine now and you don't get the horrible remus drone on long runs.
I have a Y piece with original can runs fine no problems apart from a popping on over-run did have a remus too noisey for me that used to pop even worse on over-run
i tried the mod from steptoe i thought it ran rich being a yorkshire man need to save the extra pennies so reverted back to normal
best of luck
Bob:hide
Hi,welcome.
A "y" piece is one of the best mods to do.Less weight,more mid-range and better fuel consumption.Search for the Steptoe cat code mod and try it if the bike pops a lot.
