Yes Wunderlich say not to do this, better SAE connector to battery or crocodile clips.
With this small, high-performance electric compressor, not just tyres can be filled up to the correct pressure in the blink of an eye, anything else that needs inflating can be quickly filled with air too.
The compact and lightweigt Airman (only 0.6 kg/1.3 lb.) has a built-in pressure gauge.
It connects to the onboard 12 V BMW type socket on your motorcycle, or to any regular cigar type socket. Suitable for use with a car, as it has a 3 m long power cord ( ~11 ft).
The Airman can pump up to a maximum pressure of 6 bar (~145 PSI). It is very robust and does not take up a lot of space (12.0 x 6.0 x 14.2 cm / 2-3/8” x 4-3/4” x 5-5/8”).
Supplied with operating instructions.
Note: For current BMW models with CAN-Bus, the Airman can not be connected to the standard vehicle power outlet. Here is an external power outlet necessary!
