17 00 035 Draining coolant, refilling/bleeding system
17 00 504
BMW-Motorrad/SYMB/00_MODELLE_00_warnung.gif
Warning
Take care when working on the cooling system: risk of burns if the system is hot.
Do not work on the cooling system until it has had ample time to cool down.
Preparatory work
Removing rear seat
Removing front seat
Removing centre cover for fuel tank
Removing right side panel
Removing right side cover
Removing right cover for fuel tank
Core activity
(+) Draining coolant
(-) Draining coolant
Warning
Removing radiator cap
Warning
BMW-Motorrad/BILD/1262_MODELLE_00_K50_R12018b_preview.jpg
BMW-Motorrad/BILD/1262_MODELLE_00_K50_R12018b_small.jpg BMW-Motorrad/imgs/icon/bullet.gif Remove radiator cap (1).
BMW-Motorrad/BILD/1700_MODELLE_00_K50_R17020b_preview.jpg
BMW-Motorrad/BILD/1700_MODELLE_00_K50_R17020b_small.jpg BMW-Motorrad/imgs/icon/bullet.gif Remove left drain plug (1) with sealing ring (2).
BMW-Motorrad/imgs/icon/bullet.gif Drain the coolant into a suitable container.
BMW-Motorrad/imgs/icon/bullet.gif Install drain plug (1) with new sealing ring (2).
BMW-Motorrad\SYMB\00_MODELLE_00_Anziehdrehmoment.gif Tightening torques
Coolant drain plug in crankcase
M10 x 1
15 Nm
BMW-Motorrad/BILD/1700_MODELLE_00_K50_R17021b_preview.jpg
BMW-Motorrad/BILD/1700_MODELLE_00_K50_R17021b_small.jpg BMW-Motorrad/imgs/icon/bullet.gif Remove filler adapter (1) with sealing ring (2).
BMW-Motorrad/imgs/icon/bullet.gif Install filler adapter (1) with new sealing ring (2).
Coolant filler adapter in crankcase
M10 x 1
10 Nm
BMW-Motorrad/BILD/1700_MODELLE_00_K50_R17032b_preview.jpg
BMW-Motorrad/BILD/1700_MODELLE_00_K50_R17032b_small.jpg BMW-Motorrad/imgs/icon/bullet.gif Open clip (1) with pliers (No. 17 5 571).
BMW-Motorrad/imgs/icon/bullet.gif Disconnect flow hose (2).
BMW-Motorrad/BILD/1700_MODELLE_00_K50_R17033b_preview.jpg
BMW-Motorrad/BILD/1700_MODELLE_00_K50_R17033b_small.jpg BMW-Motorrad/imgs/icon/bullet.gif Connect flow hose (1) in such a way that the projection (arrow) engages the recess.
BMW-Motorrad/BILD/1700_MODELLE_00_K50_R17032c_preview.jpg
BMW-Motorrad/BILD/1700_MODELLE_00_K50_R17032c_small.jpg BMW-Motorrad/imgs/icon/bullet.gif Secure clip (1) with pliers (No. 17 5 571).
(+) Emptying expansion tank for coolant
(-) Emptying expansion tank for coolant
BMW-Motorrad/BILD/1713_MODELLE_00_K50_R17001b_preview.jpg
BMW-Motorrad/BILD/1713_MODELLE_00_K50_R17001b_small.jpg BMW-Motorrad/imgs/icon/bullet.gif Remove screw (1).
BMW-Motorrad/imgs/icon/bullet.gif Disengage expansion tank (2) and manoeuvre it clear.
BMW-Motorrad/BILD/1713_MODELLE_00_K50_R17035b_preview.jpg
BMW-Motorrad/BILD/1713_MODELLE_00_K50_R17035b_small.jpg BMW-Motorrad/imgs/icon/bullet.gif Open lid (1).
BMW-Motorrad/imgs/icon/bullet.gif Turn expansion tank (2) upside down and drain the coolant into a suitable container.
BMW-Motorrad/imgs/icon/bullet.gif Turn expansion tank (2) right way up.
(+) Filling cooling system
(-) Filling cooling system
Sealing off hose from expansion tank
BMW-Motorrad/BILD/1713_MODELLE_00_K50_R17030b_preview.jpg
BMW-Motorrad/BILD/1713_MODELLE_00_K50_R17030b_small.jpg BMW-Motorrad/imgs/icon/bullet.gif Seal off hose (1) with hose clamp (No. 13 3 010).
Preparing and priming radiator filler for cooling system
BMW-Motorrad/BILD/1700_MODELLE_00_K43_11_R17011b_preview.jpg
BMW-Motorrad/BILD/1700_MODELLE_00_K43_11_R17011b_small.jpg BMW-Motorrad/imgs/icon/bullet.gif Fill canister (No. 17 5 553) with an adequate quantity of coolant.
BMW-Motorrad\SYMB\00_MODELLE_00_techdat.gif Technical data
Coolant, total capacity
Expansion tank
0.3 l
Coolant system, total
1.5 l
General consumable (Antifreeze and corrosion inhibitor)
BMW-Motorrad/imgs/icon/bullet.gif Connect canister (No. 17 5 553), venturi nozzle (No. 17 5 552) and distributor unit (No. 17 5 551).
BMW-Motorrad/imgs/icon/bullet.gif Put the end of the drain hose of venturi nozzle (No. 17 5 552) into a suitable container.
BMW-Motorrad/SYMB/00_MODELLE_00_achtung.gif
Attention
Pressure surges could damage the pressure gauge if you attempt to connect the compressor to the distributor unit of the filler adapter with the compressed-air valve open.
Make sure the valves are closed when you connect the compressor to the distributor unit.
BMW-Motorrad/imgs/icon/bullet.gif Connect the compressor to the venturi nozzle (No. 17 5 552).
Minimum requirement, compressor
Pressure
min 8 bar
Delivery rate
min 125 l/min
BMW-Motorrad/BILD/1700_MODELLE_00_K43_11_R17010b_preview.jpg
BMW-Motorrad/BILD/1700_MODELLE_00_K43_11_R17010b_small.jpg BMW-Motorrad/imgs/icon/bullet.gif Begin by fully opening coolant cock (1) and then fully opening negative-pressure cock (2) of distributor unit (No. 17 5 551).
BMW-Motorrad/imgs/icon/angle.gif Coolant is drawn in by vacuum from the tank.
BMW-Motorrad/imgs/icon/bullet.gif Draw in coolant until the hose to distributor unit (No. 17 5 551) is full of bubble-free coolant.
BMW-Motorrad/imgs/icon/bullet.gif Close coolant cock (1) and negative-pressure cock (2).
BMW-Motorrad/imgs/icon/bullet.gif Disconnect the compressor from venturi nozzle (No. 17 5 552).
Connecting radiator filler to cooling system
Precondition
BMW-Motorrad/imgs/icon/bullet.gif The coolant canister must be higher than the motorcycle's radiator.
BMW-Motorrad/imgs/icon/triangle.gif
BMW-Motorrad/BILD/1700_MODELLE_00_K50_R17036b_preview.jpg
BMW-Motorrad/BILD/1700_MODELLE_00_K50_R17036b_small.jpg BMW-Motorrad/imgs/icon/bullet.gif Position coolant canister (No. 17 5 553) on a higher level.
BMW-Motorrad/imgs/icon/bullet.gif Secure the preassembled radiator filler in position at the motorcycle.
BMW-Motorrad/imgs/icon/bullet.gif Connect radiator port (No. 17 5 554) to distributor unit (No. 17 5 551) and radiator filler neck.
BMW-Motorrad/imgs/icon/bullet.gif Prepare the compressor.
Pressure
min 8 bar
Delivery rate
min 125 l/min
Evacuating cooling system
BMW-Motorrad/BILD/1700_MODELLE_00_K43_11_R17010b_small.jpg BMW-Motorrad/SYMB/00_MODELLE_00_achtung.gif
Attention
BMW-Motorrad/imgs/icon/bullet.gif Open negative-pressure cock (2) of distributor unit (No. 17 5 551).
BMW-Motorrad/imgs/icon/angle.gif A vacuum builds up in the system.
BMW-Motorrad/imgs/icon/bullet.gif Evacuate the cooling system until the requisite vacuum is established and the needle of the pressure gauge is steady.
Requisite vacuum for filling the cooling system
min −0.8 bar
BMW-Motorrad/imgs/icon/bullet.gif Close negative-pressure cock (2).
BMW-Motorrad/imgs/icon/bullet.gif Observe the needle of the pressure gauge of distributor unit (No. 17 5 551) for a time and check that the partial vacuum in the cooling system does not rise to ambient pressure.
min −0.8 bar
BMW-Motorrad/imgs/icon/bullet.gif Slowly open coolant cock (1) until it is fully open.
BMW-Motorrad/imgs/icon/angle.gif Coolant flows into the cooling system.
BMW-Motorrad/imgs/icon/bullet.gif When the level of fluid in the canister (No. 17 5 553) ceases to drop and the vacuum corresponds to ambient pressure, disconnect the radiator filler from the radiator.
Disconnecting radiator filler from radiator
BMW-Motorrad/BILD/1700_MODELLE_00_K50_R17036b_small.jpg BMW-Motorrad/imgs/icon/bullet.gif Disconnect the radiator filler from the radiator and remove it from the vehicle.
