Andy Leeds UK
As at least some of you know, my F went pop in Morocco and limped back to Spain where I left it to the RAC. Oil temp went mad (160 degrees after 10 minutes at 50 mph, water light on). Having had the thing in bits, I'm honestly stumped:
The thermostat works, a whole 9mm longer and definately open when boiled with a couple of eggs.
Pouring water into the radiator with the drain out gives an unimpeded flow. The radiator is water tight and allows flow.
The water pump impellor turns with the engine on the starter motor.
The oil is black/red not brown. The oil level has not changed and the oil in the reservoir thrashes round when the engine runs. The oil pump seems Ok.
The water level in the tank did not change, yet when you block the overflow and fill it, the water goes along the pipe into the radiator filler cap.
Now, since checking this stuff, I havn't refilled and run the engine, but I can't find a fault. Only thing left that I can think of is the dreaded idea that the water has not been able to flow up the engine due to some blockage inside or there was some sort of vapour lock.
Anybody have any ideas or do I just refill and take it to the dealers if the oil temp still does crazy and the water light comes on?
Don't mention the gallon of petrol and box of matches, I already thought of that!
Andy
Andy
