gavin
When changing oil and filter, do you guys get the motor hot enough (R1150GS) for the oil cooler thermostat to open?, if not, is there a small amount of oil trapped inside the cooler and pipes which will affect the level once refilled? And when refilling, do you put the amount in as specified in the handbook/manual, or go by a visual check on the oil sight glass?, i am a bit confused!.
