crown wheel output bearing
(RIP) john plane
ascot
Can any body help my old bike bmw 1100r. which i sold to a friend of mine has failed the mot. He thinks its the crown wheel output bearing. Is it an easy job to do the haynes manual says take it to a dealer. My friend is good with british bikes old bmw, s. but never took a new bm bevel box apart before.thanks a lot john.
take the wheel off, undo the rear brake caliper and tuck it out of the way.
Drain the oil from the bevel, undo the 8 bolts that hold the bevel face on , tap it off with a soft mallet, carefull the inner doesn't drop out .
You'll see the bearing on the crown wheel, its shimmed, so check that it is the bearing that u/s .
Before splitting the bevel, check its not play in the paralever pivot, this can also be adjusted a certain amount, you don't even have to take the wheel off, its the inner bearing/pin on the swingarm that you adjust.
this is the paralever pivot pin
this is the bevel -
this is the shim -
thanks a lot
thanks a lot steptoe. Will see you saturday morning when i show andy your house.
That's an excellent reply for all of us, now we know what it looks like.
finglonger said:
WOW thats good service you stripped one down just to show John how to do it.:D
just happened to be working on one .
:D :D
And good business sence too. After some of us have had a go we will bring the bits to you:D
mmmmm....
my airhead (R80G/S) has a wobbly rear.
i stripped the bevel drive and it looks the same as that one. do i change the bearing and the shim or just the bearing. i couldn't feel any play in the bearing when it was apart.
i think i know how to use marking blue to get the shimming right.
Re: mmmmm....
try re- shimming it, will only cost you pennies, rather than the cost of the bearing !
