cutting out
Ginger DJ
Rochdale
Why has my trusty GS suddenly started cutting out whilst on the move. Never done it before and twice on my way home from work. Has anyone else had this problem or is my bike just shagged?
Check out the wiring from the ignition 4-5 wires in side a black outer sheath just around the head stock left hand side peeel back you may find frayed wires I fix a 650 for a work colleague not long ago same symptoms.
Exactly my problem too.. warmed up engine then usually as I clutch in to slow down for a tight bend it just stops.. I find myself hitting the starter switch while on the move clutch in.. very disconcerting..
Having to keep revs up while slowing or clutching like it was some kind of old banger that has no tickover.
Will try them tips too, thank you guys.
