'99 R1100GS, 53K miles. Recently lost power and developed a knock from the right hand cylinder, whilst riding on motorway. I'd checked engine oil level before starting journey (by leaving up-to-temperature machine on centre stand for 5 minutes after switching off, and then checking window. Level was just above centre of window, where I aim to keep it). After onset of symptoms, I checked again and oil level was below window after journey of only 300 miles. Compression test showed 160psi in left cylinder, 90psi in right.
After a couple of fruitless sessions spent checking valve clearances and rocker/cam assembly and cam-chain tensioner, I pulled the head this evening. Saw visible damage to the bore, so pulled the cylinder. The top ring is seized in it's groove, and there is damage in the form of heavy scuff marks to the piston and to the cylinder wall. The cylinder damage can be clearly felt by running finger up and down the bore.
Question 1 is this: Can oilhead cylinders be refinished, or would it make more sense to look for either good secondhand or even (gulp) new parts.
Question 2: The right hand piston is definitely dead. Am I right in assuming I will have to buy pistons (and, presumably, cylinders if refinishing is not possible or not recommended) for both sides, or is there any chance I could get away with replacing only the right?
Oh yeah, and while taking exhaust off to pull head, I sheared an exhaust stud. Intemperate language was used....
As to the cause, the machine is fairly new to me and came with Remus Revolution, Y-piece, K&N air filter, no cat., no motronic coding plug and standard 'chip'. Although I have never heard it pinking, it does pop on the overrun. I have been a bit uncomfortable with the idea it may have been running too lean, and it looks as if I may be paying the penalty for not taking the trouble to check it out. And to compound this, I found a split in the rubber throttle body stub that I am guessing may have allowed air to be drawn into the right hand cylinder, compounding a potentially already lean condition.
Sorry to bang on at such length. Advice/experience/opinion much appreciated.
