worthydolt
Dear All,
I have a bit of a persistent oil weep from the left hand cylinder head gasket of my 96 R1100.
I've replaced both head gaskets with the new 3-layer ones and the RHS is nice and dry now.
Steptoe's sticky on this job was my guiding light. Thanks man!
The LHS was leaking immediately after I replaced the gasket and, I think, from a different place than before I replaced it. Although I'm not topping up the oil any more than I was before, it's more a weep than p*ssing out.
So, last weekend I pulled off the head again and gave everything a look over checking for casting imperfections and cracks. I couldn't see any.
I then laid a spirit level both on the head and on the face of the cylinder. It all seems nice and flat.
So I put it all back together and bolted it all down as per the BMW manual. 20Nm then 90deg then 90deg on the four nuts, then the 40Nm stud, then the little stud near the cam sprocket.
I've pretty well run out of ideas now. If anybody can see anything I haven't thought of (BTW I've also replaced the doughnut washer around the spark plug) I'd be really grateful.
If not, I'm looking for recommendations for a good garage who I can hand the problem over to. I'm near York.
Cheers,
Neil
Cheers,
Neil
