Using Steptoe's excellent howto I've just removed my left hand head in order to change the gasket.
However when bringing the cylinder to TDC, I neglected to check that it was TDC on the compression stroke rather than exhaust. This matters because on compression, inlet and exhaust valves are fully closed and there is a couple of degrees freeplay in the camshaft which aids refitting the cam sprocket onto it's keyway.
On the exhaust stroke, TDC actually has the inlet and exhaust valves cracked open slightly (exhaust just about to close, inlet just opening) which means that the camshaft is locked solid by the valve spring tension and there is no freeplay.
The way to check that you've got it right is to make sure that the inlet valves are closing as you approach TDC (or bring it to TDC and see if you can wiggle the rockers as if you are going to check valve clearances - if they feel solid, turn the engine another revolution and try again).
I of course didn't do any of this and only realised when I got the head off and noticed both valves open slightly. I'm probably going to have an interesting time trying to refit the cam sprocket
