Alright, micky guilted me into going and getting the toolkit
first pic is basically what came with the bike, minus a few torx keys and fuses.
18mm sparkplug spanner, flathead / philips screwdriver, small philips screwdriver, 14 & 15mm spanners (only use i found for them was adjusting the mirrors) You can do the square root of feck all with that lot. Apart from adjust the mirrors that is
second pic is what i added
19 & 24mm spanners to loosen the rear axle, 6/5/4/3mm alan keys, cheap multitool for the pliers, adjustable spanner, t 10 - t40 torx bits & driver, 5 - 10mm sockets, all that's missing is a t45 torx bit for the front wheel. That is in the little storage box at the back end of the bike, along with eletrical tape and cable ties.
All that stuff is on the bike at all times
Mainly cos its out of the way in a tool tube. I figure i'll at least be able to take all the panels off to get to the battery / airbox, remove the wheels to repair punctures if needed and fix broken wires / loose stuff. Having said that i use the tools at home more than when i'm out. (or on my mates ducatti but we'l not go there
Before anyone calls me a heathen for having an adjustable spanner, that thing saved my butt in the lake district. One of the 3 bolts holding the footpeg mount on decided to part ways, cue me standing on the pegs and bending the mount
Using the spanner as a mini clamp (and a long piece of hollow bar) we bent the mount back into shape enough to be able to put in the bolt we'd borrowed off the local farmer
I'm looking into getting a puncture repair kit and a set of tyre lever for my trip upto scotland, already got the pump, freebie from work
duuno if its worth it tho.
I've got one of those cards micky, runs out in may i think (dunno where it is tho)
