Decent mechanic, stafford/stoke area
neuroportal
Member
North Wales
Wotcha.
Anyone recommend a decent garage for a monolever (RT)?
Two things I want sorting/checked out. There is a clunk, intermittent, either the Driveshaft or final drive, but it only seems to occur in first. Can't quite make it happen on demand.
The other is the idle racing at around 3k when engine is thoroughly warm. At first the beancan was suspect, however the revs climb back up without help from the throttle. Tried the boots can can't find an obvious airleak. It also starts well and idles at 1k in current weather, from cold with no choke at all so it may be just needing the throttle stops setting.
Indeed, if anyone is in the Stone area at any point, I would welcome an experienced opinion. My only airhead experience was an R80ST owned for a month!
Ta.
Wotcha.
Ta.
Give Adventure Bike Warehouse a call on 0161 736 8040. I'm sure Jono will be able to help. They are in manchester but that isn't a million miles from you:thumb
