Hello
Got the parts yesterday, apparently my local postoffice forgot to tell me it was there, a "mere" 10 day delay due to someone leaving the slip that they were supposed to leave in my mailbox on the actual package.
So far everything looks good. Included int the package were lowered adjustable footrests, a magura x-line handlebar for heated grips, brackets to fit acerbis handguards to the x-line, and the desierto I.
I can see that TT has fixed some of the previous problems with the desierto. For instance the brackets that fix the lower part of faiirng to the base of the beak has been altered.
There is also another pair of rebber bushes to go between the new subframe and the actual fairing. I dont know if anyone read the Dessie project from a dutch guy living in Denmark, but apparently he had a problem with the subframe not fitting properly to the instruments. I do not belive that his Desierto included these bushes.
I did a dry-fit today, and It looks good so far, It is definately taller and slimmer than the OEM screen, not as dark. The instruments are brought a rough 3 inches higher up and slightly more vertical. Included in the kit is a new speedo cable as the one would be a bit on the short side.
Pictures to follow if anyone interested, I just have to become a sponsor first.
The only major problem so far is the screw that fixes the left heated grip to the handlebar, it just rotates and I cant seem to get it out, looks like chainsaw massacre
will be needed to separate the outer part of the grip from the stock bars.
