Device Manager Errors
TJ
Which Way....??
North Yorkshire I believe..
Could someone please tell me what are all these errors. Is it as I suspect my Hard Drive is on it's way out, or could it be caused by my power supply unit.
Thanks in advance.
T
My computer- R/click Local disk 'C',
then L/click 'Properties'
then select the 'Tools' tab
then L/click 'Check Now'
Put a tick in the 'Automatically Fix errors' (leave the other blank)
Press 'Start' and then choose the option to run the check when you restart your computer.
Restart the computer and let it proceed to fix the file errors, it should only take about 2 or 3 minutes but sometimes can take a lot longer.
