KevinW
I'm currently sitting in a hotel in Slovenia where it is absolutely pouring with rain; nice roads though .
Just before I left I had an alarm and HID fitted and that seems to have disturbed something relating to the digital display. Not long after I pulled away from the workshop I realised something was amiss and went back. There are three plugs underneath the tank (actually, thinking about it there might be two tiers making six but, if there are let's just concentrate on the top three). The mechanic disconnected then reconnected the rh plug, the display came back and off I went. The following day it happened again twice and I was able to repeat the trick. Unfortunately I had no time to take it back to the workshop before we left.
I originally thought there was something wrong with the plug but I can see nothing wrong with it and, thinking about it some more, I've come to the conclusion all that is doing is removing the power and resetting the display and the fault is somewhere else (I could be wrong of course).
Anyway, the display was 'gone' again this morning (no temperature or fuel gauges, no gear indicator, clock displaying a time but static). I did the usual diconnect/reconnect trick with the plug which resolved the issue, put the tank back on, turned the ignition back on and now have a different issue with the display - fuel and temperature guages are full with a few bars missing in the middle, gear indicator shows zero, clock static and they remain on even with the ignition off.
I'll have a look in the morning and, if I can't see the issue, will see if there's a BM dealer in Ljubljana who can help (which is more than the one in Innsbruck could do this morning).
The display was working perfectly before I had the alarm and HID fitted so I think it's a wiring issue rather than something wrong with the display unit itself. Do you have any idea what it might be to help me troubleshoot in the morning?
I realise I can do without the display if I have to but we're three days into a 5 week trip so it would be good if I can get it sorted.
Thanks.
Kevin
Thanks.
Kevin
