DIY radiator guards
Rich1150
Newcastle
On other bike forums I have been on there Is always loads of DIY activity but not here. It must be because the bikes are expensive and we are all a bit posh.
Anyway after buy a £15k bike and all the headlight protector, mudsling, hand guards, engine bars, head guards, mudguard extenders.........etc etc. I realised I didn't have any radiator guards and need to spend another £80. Hang on a moment if I could not make some of them in half an hour for £10 I am loosing my touch.
So off to B&Q bought some aluminium mesh, took the radiator surrounds off (three screws), cut the material with scissors and left a tag at the bottom to take the fixing screw. Clip the cover back on, screws back in and bosh job done.
Sent from my SM-G935F using Tapatalk
You could have
bought 2 disposal bbq's , had yer lunch and free rad guards, probably look better on a tripple black with the charred look .
You could have
We don't want your type on here; we only buy Touratwat and Wundalick. Now off with you :rob
PS. Good Job :thumb2
I'm off to B&Q then.... great tip, thanks for sharing.
I feel a 'what did you make your rad guards out of?' thread starting. Can't wait for the croshay ones. Machine washable, do not tumble dry.
I used woven stainless wire mesh on my Hexhead oil rad. Costs 2p on eBay and needs more effort to get a clean bend but it's still there after 3 winters and it looks OEM.
Sent somehow.
Looks great! :thumb although they may start to corrode quite quickly (just a thought)
Was in B&Q for a totally different reason when i happened to walk past the area that sell the mesh...:augie. So, on a whim, i have bought some and as luck would have it, have some black spray paint :clap.
So the weekend job will involve some cutting and painting for the rad guards followed by the install of the HEX ezCAN.:thumb2
:hapybnce:
Engineering at it's best, simple, cheap, reliable..top marks! :clap
gws-serp..1.7.1558...0j35i39k1.S7pmSLP7tmg
Why not buy black plastic mesh to start with
Sent from my SM-G900F using Tapatalk
