Normal-sized people like us
Talljohn,
Welcome to UKGSer!
I'm 6' 6" - I've got an 1150GS (not Adv - they are about 25mm higher than standard GS's, longer side stand etc.).
First change is buy Tobinators (from
Nippy Norman, link at top of page) - std screen WILL buffet. Whatever screen you have can then be altered in angle/height - I changed the screen (I had an Adv one originally) to a Wunderlich one which is massive but I like. MVA Vario gets good votes; there are plenty to choose from (TT, CeeBailey etc)
I have a 40mm higher std seat (custom build - bought off this forum) - any good seat man will rebuild a GS seat to your spec. Plenty of threads (search "custom seat" or similar). One tip is too ensure the front of the seat is built-up more than the rear as you sit further back so the "sweetspot" needs to be moved back too. I modded the mounting frame under the seat for c. 10mm more by adding longer bolts with spacers - the gap to the tank is not too bad as I have a tank cover on.
I have bar-backs, not risers, these bring the bars back about 30mm to let me sit more upright/further back. Don't know what make, bought (like everything else) secondhand on this fine forum.
I've just bought some MV footpeg lowerers but they've not arrived; these should address legroom BUT usually compromise cornering clearance and/or brake/gear pedal (TT do a modified gearpedal) so time will tell. Other pegs which are lower are available too - e.g. Fastway, Wunderlich and TT. Some people simply remove the BWM rubbers to get a but more space (and vibes)!
Basically I bought a GS thinking it would be big enough but in truth they aren't that big, but modding is all part of the fun and there are plenty of solutions out there! Still love the bike after 3 years.
Hope this helps
A
