glennis
Hi all,
Recently acquired an 06 GSA with 7k under its belt and have so far been loving it, however on the weekend I was stranded by a flat battery
As I am planning a trip to Oz in 12 months on the bike, my confidence in the reliability of the GS took a bit of a nose dive and after reading several threads in ukGSer it seems some bikes (or batteries??) suffer from short battery life spans or batteries that just fail without warning.
As a possible solution to avoid being stranded again by a flat battery, has anyone had or heard of a dual battery system on a motorcycle like those found in 4WDs? It would also be great for powering camping lights etc.
I envisage the system working as follows:
Aux/second battery is disconnected from main battery when ignition is off.
Engine is started and aux battery is connected to main battery via a relay (or solenoid) that is energised from the head light wire (as this is only active after the engine has started). Switch bike off and relay/solenoid disconnects aux battery. Would also build a manually operated switch (to operate solenoid) that connects the aux battery to start bike if main battery fails.
My major concern is that adding a second second battery will effect the charging characteristics of the main starting battery or somehow confuse the the EMC/ZFE and not charge the battery correctly.
Does anyone have any comments on building a system like this as I am not familiar with the electrics on the GS particularly the can-bus system.
Might also just squeeze in 1 stupid question. In the interest of size and weight constraints of a second battery, could the aux battery be substantially smaller with the idea of just providing power for fuel pump, EMC etc and then push start the bike?
