mrTickle
Sorry this question isn't bike related but hopefully someone may be able to help me out...
I've just fitted a car alarm into my car. It's working great but I've got a very slight problem. The alarm has one wire coming out of it which sends a +12V pulse when the alarm keyfob is pressed. This 12V wire is meant to be connected into the cars indicators circuit, to give a visual indicator when the alarm button on the keyfob is pressed - the indicators blink twice for arming, once for dis-arming.
I don't have a wiring diagram for my car, so I decided the simplist method was to hook the 12V wire into the cars hazard light switch. The problem I got doing it this way, is that I can only wire the 12V wire into one side of the cars indicators. If I wire it to use use both sides indicators, when the ignition is on and I indicate to turn ( say left ), all 4 of the indicators come on together instead of just the left hand side indicators. Does anyone have any advice on how I can get all the indicators to flash together for the alarm ( maybe using a relay or some other alternative ) and that doesn't make all 4 indicators flash together when I'm indicating which direction I'm turning? Cheers in advance
. There are 8 wires going into the back of the hazard lights switch, and out of that lot I definately know the 2 for the indicators. I'll pop down to Maplins, get meself 2 blocking diodes and scotchlock 'em in.
