powroll
Its a fag taking the swing arm out every chain swap, do any of you use masterlinks ?
Any breaks ever?
Any breaks ever?
i had a chain on the dakar (pretty much the same engine as the g bikes) that had a spring clip, bloody clip kept coming off. Installed correctly (we use the same type of clips at work, on smaller 1/2 pitch chains) Lost the clip three times before finally deciding enough was enough and fitting a rivit type master link.
Something was wrong there then. When the circlips are new, you can barely get them on or off using tools - they certainly won't fly off on their own.
However, just re-reading what you've written, you may not have been using the original circlip for the chain. The pins over which the circlips fit are NOT a standard size so you may have ended up with (what is known to us in the trade as... ) a piss-fit.
Greg
) came off repeatedly, usually after a longish ride
