Error message???
Banger
Yorkshire Dales
Anyone know what or why this message keeps coming up. It drives me nuts you can either press yes or no at the end so i just press yes to get rid of it but it takes about 5 clicks of yes before it goes. Bloody enoying- Happens on most websites.
It says:
AN ERROR HAS OCCURED IN THE SCRIPT OF THIS PAGE
LINE 5
CHAR 1
ERROR- INVALID CHARACTER
CODE 0
URL.....................(what site you are on)
DO YOU WANT TO CONTINUE
YES NO
It pops up in a grey box and takes up half the screen?
Any ideas wizzkids?
Symptom:
When opening a page within Internet Explorer (version 4) a dialog box is displayed titled ‘Internet Explorer Script Error’ displaying the message:
Line: 1
Char: 1
Error: Invalid character
Code: 0
Do you want to continue running scripts on this page?
The line, character end error message might vary slightly.
What the error means:
Internet Explorer is displaying this message because it has encountered this error when trying to run some JavaScript on the page.
Probable Cause and Remedy:
* The most likely cause of this error is that you are using a relatively old version of Internet Explorer (i.e. Internet Explorer 4) and it cannot deal with something on the page. Consider upgrading to a more recent version of Internet Explorer. Otherwise select 'No' and see if you can continue with the page being viewed.
* See also Internet Explorer: A Runtime Error has occurred, which covers the same error but for later versions of Internet Explorer.
Banger Try,
Select 'Tools' / 'Internet Options'
Select Advanced tab,
Make sure the 'Disable Script Debugging Internet Explorer' is checked
Also 'Disable Script Debugging Other' is also checked.
Click 'Apply' OK
As below,
