Ethernet or USB hub
Deadskin
Cloppa Castle
Getting broadband soon
and as i've only got two usb ports,both being used,
is it worth getting my pc Ethernet ready or just buy
a usb hub ?
Gates :chewstick
Plug and Play
Hi
I had a plug in port for Enternet in the side of my computer already so that was the answer! Cost - Nothing.
HTH, Nick
Ethernet. If you are going NTL Broadband the set top box uses an Ethernet connection which you can either plug into your computer or use the adaptor to plug into a USB port.
For the price of an ethernet card for a PC, cost a tenner from e-bay last time I bought one, you will have a more direct connection and I believe it will be a faster because you are not sharing the port.
Andy80F
I have NTL bband. Their supplied modem has USB & ethernet options.
I share the connection with 4 other PCs in the house so we use the ethernet connected to a wireless hub.
I only have 2 USB ports on my laptop so invested in a hub for printer, mouse etc.
I have to plug my wireless adapter into one of the PC USB ports as the hub cannot cope.
Do as Andy suggests and spend a tenner on an ethernet card for your PC. Just make sure you have a spare slot on your motherboard (you may be able to replace the modem card if you do not).
