HMR said:
I mounted an external amplified antenna but... I had problems with antenna signal closed loop. The antenna is mounted a little too close to the GPS...
Interesting that you should encounter that on a motorcycle installation. There is a general rule in aircraft GPSR antenna installations that no antenna should be closer than one meter (one yard) from another GPS antenna. I didn't think that would be an issue with automotive installs, but, I guess it is something that has to be considered.
On my bike, the antenna is about 6 inches away from the GPSR, mounted on top of the right hand brake fluid reservoir (just inboard of the throttle grip). It has worked OK in that position with a great variety of GPSRs (296, 25xx, 26xx, 27xx, 7xxx, etc.) but maybe this has to do with some other factor - perhaps I have a different antenna than you do, or the cabling is different, etc. It has quite a good view of the horizon from that position - my body blocks about 15% of the sky view, but that doesn't seem to make much of a difference to performance.
One thing you may want to experiment with (to eliminate the need for the metal shield behind your GPSR) is shortening the cable between the external antenna and the connector so that the cable is no longer than it reasonably needs to be. Normally, external antennas are supplied with about a 3 meter (3 yard) long antenna cable, which is far more than we need for motorcycle use. The easiest way to get the cable shortened is to take it to an avionics (aircraft electronics) shop at an airport near you. These shops have the tools and test equipment needed to do a 'military spec' job of fitting a new connector onto the end of the cable, and then testing it to make sure that the connection is solid and performs as it should.
Michael
External Antenna fitment - my moto
<a href="http://www.hostdub.com/PanEuropean:Remote_on_Moto_2720:full"><img src="http://www.hostdub.com/albums/PanEuropean/Remote_on_Moto_2720.jpg" alt="hostdub.com"></a>
