F800GS KEEPS STALLING
nugget
Member
oxford
My trusty steed has developed a problem recently! it will stall immediately whenever i select first or second gear, well any gear, this is without releasing the clutch.
side stand up of course, i cannot see anything untoward relating to the clutch or gearbox! would i be right in thinking there is a sensor within the gearbox that is not working and keeps cutting the engine, never had this problem before and does anyone have any ideas as to what the problem might be..:bow
could be a faulty side stand switch which is not registering that the side stand is up?
Alan R
I have been reliably informed that it's most likely to be a faulty side stand switch!
Thank you Mark 71 and Alan R
I think there was a recall on this. I know my 800gsa was done under recall. Jjh
Had an issue with side stand switch lucky just wriggled the wires leading to it and that did the trick :thumb
Just solved a problem like this with my brothers 950 Adventure, the battery terminal wiring had snapped and would jolt off when kicked into gear. Cheap fix and easy to check... Have a look
Good diagnostic fault-finding. Check the simple stuff first. :thumb
Hi Nick the side stand was faulty so I bypassed the switch by joining the White and red and floating the brown works a treat! BMW wanted £93 for switch and cable😣hmm really not paying that.
Thanks for the link mate
Regards John.
