Firmware update Zumo 5XX version 4.50
ECM
Netherlands, Zoetermeer
Change History
Changes made from version 4.40 to 4.50:
* Fixed speed camera alerts toggling off and on.
* Enhanced GPI support.
Available over your Webupdater or on:
* http://garminzumo.wikispaces.com/Firmware (also older firmware)
* http://www8.garmin.com/support/download_details.jsp?id=1907
If you update over the Webupdater, there is also a GTM Trafic Receiver update:
Changes made from version 5.10 to 5.20
* Add dynamic priority for pay service where free is available
* Display "lifetime" for clear channel lifetime entries
To avoid errors / mistakes while using the update procedure, temporarily remove your SD card.
Quote:
Change History
I have done the update but how do you use the Toggle on/off feature for the speedcameras?
Ian
The toggling wasn't a feature, it was a bug. The speed camera alerts would flash on screen for such a brief time period that you could barely see them. 4.50 was really a bug fix to stop this from happening.
If you want to turn the speed camera warnings on/off go to "Proximity Points", then "Change" the Proximity Alerts. They you can switch on/off "Garmin Safety Cameras".
TobyS
