At long last after a four week wait it has finally arrived my Ti Remus to go with the y-piece.
Remus now go to great lengths to point out a couple of things, typed as it is written on the box:-
ACHTUNG! WARNING!
When silencers without the sound tube are fitted or when travel cases are used is this end pipe extension part Nr 087799 required to protect the indicators and the travel case. When using the travel cases the inner travel case should be protected with a heat resistant material BMW part Nr 46 54 2 316 611.
The first job was to remove the sound tube, how easy could it be? drill the one rivet out and remove the tube!
Started the bike up............
feck, thats loud!
Refitted sound tube and started it up again, arrrr....thats a bit better.
Just need to road test it tomorrow after the sealant has cured around the joints to see how it performs.
That said the noise check was not really a true test coz it was done inside the garage so it echoed around the walls and made it sound louded that it was.
I would hope after shelling out so much dosh I will run it without the baffle. Out of interest how do people run theirs, in or out?
Plus reading the warning note on the box, it would seem that if you have the sound tube out and ride it without the end pipe extension fitted you could melt the indicator?
Lastly, remaining inside the box were two M8 x 20 s/s nuts, bolts & spring washers, plus one M8 x 20 s/s bolt, these are over and above the two bolts that secure the mounting bracket to the can.
WTF are they supposed to be for then??
BTBR
ACHTUNG! WARNING!
feck, thats loud!Refitted sound tube and started it up again, arrrr....thats a bit better.
BTBR
