Fitting clear indicator lenses
tommyboy
Elmswell, Suffolk
How much does it this mod cost?
I assume they are a straighty swap for the amber ones already fitted?
:beerjug: Tom
Assuming all you want is to change from amber to clear, then it's just the lens cover and four bulbs!
Be careful if your just swopping the lenses -
The reflector/mounting frame is different, you can break the small tab on the clear lens .
cheers guys
looks straight forward now the tab/indicator research has been carried out by other unfortunates!
How much are BWM likely to relieve me of for 4 clear lenses?
Tom
Nippy does them, or for about the same amount www.alternatives.com if you want to get an exciting parcel from Vegas! Bulbs come with the latters. Worked out about £20. Think they are a £25ish option on new bikes. I must say though the tabs break easily, one of mine was broken on delivery and is being replaced.
Also I'd recommend the silvered bulbs. The lenses have a large clear area so still look quite orange.
