Where did you get the LED from? It's just you'll need to wire in a resistor in series with it and the value of the resistor depends, to a point, on the exact type of LED. Alternatively, can you see any paperwork you got with it that tells you the forward voltage, or Vf and the current it requires (If or forward current)?
If it's Maplin, can you quote the part number?
