So the time has come to do the above, do I really need a funnel and filling adapter contraption? There isn't much of a head on the reservoir in the module, worries me it'll run dry...?
Yes, you need the BMW funnel / contraption thingy, or make yourself one with a funnel and bung. Once you have this it is easy peasy. Done it several times.
If you haven't got details on what to do I have a pdf.doc send me your email address and I will email it to you.
He's right you know! all you have to do is to make certain the fluid level remains up. As long as you follow the procedure/order of bleeding it's very easy. As i think I have said before (it's old age you know) I replaced all the pipes and bled the system in less than two and a half hours.
Certainly easier than on some bikes where bleeding the air out can be a real pain.
