Hello every1.
As you might know I am pulling apart a f650gs motor. Everything is nearly of that I can take off. Finally succeeded in removing the timing/flywheel nut off using heat and a long breaker bar.
Now to take off the flywheel without damaging anything. This can easily be done with the "Official BMW Flywheel Puller". Problem is that the likelyhood that the dealer will lend it to me is... well you know...zilch, nada, niente.
So I turn to you dear friends for some advice. I am not sure a conventional puller will fit the assembly as the gasket surfaces very close to the wheel.
Thanks in advance.
G
Thanks in advance.
G
