Thanks for the link yes Im an aircraft engineer but I have manuals to look at with pictures and stuff looks by that link that someone has cut the springs at some point
I implied, that if your were clever enough to work on aircraft, you could work out how a simple spring would fit. Manuals don't show everything, sometimes basic engineering knowledge is needed. I suspect you have that in spades.
Thanks for the vote of confidence it would seem someone has cut the looped end off the springs and the mounting holes were full of grime and not easily visible
I used to have a full time job repairing broken components that
"aircraft engineers" had broken due to not following the basic rule of RTFM
ps
Job title changed on ukgsr to reflect actual job role!
I think we have already been there but you wouldnt let me have your world beaters
good luck with your sale though dont suppose you still have the touratech centre stand plate
As a matter of fact I do... its attached to my 1100. Whoever buys my 1150 can choose which one they want. I also had one of those light/oil cooler guards you were after.
