Footrests
wreck diver
worcestershire
Do the foot rests from a 1200 GSA fit a G650??
Reason for asking,standard Sertao pegs are 25 mm ish higher than the pivot pin ,
And GSA pegs sit at the same level as the pivot pin so would give me a bit more leg room.
Thanks.
I have Fastways on my Dakar and on the NN site they're listed the same for the 650, 700, 800, 1150, 1200, ADV and LC. I would therefore assume 12adv footrests 'should' fit. Not tried them though.
The Fastways sit much lower than the standard footrests. I've also got the adjustable footrest brackets from Ratel which means I can get them much further back and lower than standard.
Many thanks for that.
I have them on my sertao. They fit on fine, but cannot pivot back without catching on the frame mounts - at least mine do - they are on the low setting (spacer above). Which as an aside moves them slightly further back than standard making the gear lever a little far forward so i ended up with a tt adjustable gear lever.
