Forgoten how to set a date......
Banger
Yorkshire Dales
On the p.c so i can backtrack to that date if i loose something. Its like a calender .
Can somebody describe the procedure I have XP Thanks
Right-click the time of day on the bottom right of the status bar. One of the options is "Adjust date/time"
Mike
I presume you mean system restore.
From the start menu select control panel,then a folder called system, then in that folder you should find a tab at the top that says system restore from there it should be easy you get to choose your options after ticking the Turn on system restore box.
Hope that helps Pete A
