Fork spring spacers
fayeslane
Albury, NSW, Australia
Changing the fork oil on the G/S -drained OK but couldn't get any oil back in :confused:
Took the cap off and found that someone had used coins to preload the spring -that's fine but there is no hole for the oil run in :blast
If going down this path select a currency that has the holes already there :thumb
I turned some spacers up on the lathe and once again realised that owning a lathe doesn't make you a machinist :eek:
The up side of this experience is that I am 80 cents richer :)
Don't you just love previous owners bodges? Sounds like your just the man to sort it especially with a lathe to hand.
A mate of mine bought a Suzuki T500 years ago where the previous owner had welded a section of the barrels to the crankcase to cure an oil leak so the bike could be sold. Nice neat bit of welding though :D
I p/ex'd an Ariel Arrow in 1966...
Only prob was I'd had a piston malfunction [ hole in crown :( and they were £1.5shillings for a new one, a weeks wages almost :rob }2 days after deal was done with Walsall Bike Mart...[ long since defunct ]
My good mate {a pattern maker} turned a perfect rep' out of a lump of Mahogany, inc putting the ring slots in and making the gudgeon pin fit to within a 1000 of an inch :eek:
It started :thumb
So it was taken by van to within 100 yards of the shop, and rode in, switched off :augie
Blokey came out looked it over again, kick started it:eek, revved it :eek: and rode it into the workshop :hide Came out and said "sounds great" we did the deal and away I went,, never heard nothing from them, ever :augie So it might still be in there :D
As an aside, the pattern maker retired last year and he said at his party that he'd so wanted to enter that piston as a test piece in his City and Guilds exams...
Much alcohol was consumed reminiscing over the tricks we used to get up to :blagblah:blagblah
Did you do that so it wood go or was it to give the exhaust note a bit of a bark but maybe you should leaf such things to the experts...
eeeeeeeee having fun here:D
I think he thought he could branch out a bit, but might knot be able to get to the root of all evil... daft old sap:D
John
I wonder if the buyer twigged that the engine was rooted?
That piston is probably packed away in a trunk somwhere gathering saw dust. :augie
Shouldn't that be "take the pith"? :)
Bonus points to the first bloke to work "medullary rays, phloem & cambium" into this amusing line of drivel :D
I think you've just done me a favour there, young man - I recently stripped the forks on my R60'7 to replace the head bearings, and after it was all back together, there were two largish ali spacers left over !! :toungincheek
I think, reading this, that is where they SHOULD have gone !!
Mike
Mike,
I made up and put spacers in because the Clymer manual shows an "intermediate ring" on top of the spring seat and this wasn't present when I took the top off the forks. The front end on my G/S feels undersprung and too soft so any additional preload is welcome. Ultimately I would put in a new set of aftermarket progresssive springs but spending on this bike is not priority at the moment.
I put 5w fork oil in because I had it on hand, but I don't like the feel of the damping. Will change it for 10w and see how it goes.
The diagram below might shed light on what goes where on your 60. :thumb2
I managed to weld the piston to the cilinder head on my RD400 drag bike. I was doing about 120mph at the time :blast
Val.
