FRAME BAGS WUNDERLICH
  • Thread starter Thread starter cowboy
did you put the frames flush with the outside of the bars or did you recess them with the p shaped clips
I fitted them flush, I thought about recessing them but decided it was too much like hard work, mine are quite a tight fit, I wasn't convinced the bags would fit OK if they were recessed....;)
Thanks funners did try them the other way just could not get last nut on,also the nuts were too close to the tank if the bike went on its side then they would be up against it and could do some damage cheers for the help
