Might as well replace the piston in the master cylinder. You can get one from motobins with the new seals already on fairly cheap. Put new washers on the banjo union as well when you build it back up. Have a look inside the master cylinder for any signs of corrosion etc. Minor stuff can be smoothed out with fine emery cloth.
Got to be worth a strip down mate. Easy to do and its one less thing to eliminate. You can also set the plunger at the correct level as well then..
. Though they can be overhauled too, it is an expensive work
